January 28, 20224 yr Having issues with the Bluetooth capabilities of this remote. Although the remote remains paired (IR) in the settings, it does not maintain its Bluetooth pairing. It only stays Bluetooth connected for a minute or so before reverting back to just regular IR. Reconnecting to Bluetooth then becomes an issue, sometimes freezing the whole system until the Bluetooth pairing functionality stops the pairing process (gives up) unconnected. After numerous attempts it will connect via Bluetooth only to lose connection within 5 minutes max. If I turn off the STB (power) while connected to Bluetooth, the next time I power on, it does not re-establish the Bluetooth connect again without having to go through the whole "add a device" process. I have subscriptions on it so I'm hoping for other solutions other than resetting the whole box to factory as that would create a whole other headache. Any thoughts out there?
January 28, 20224 yr Author 26 minutes ago, dishuser said: wifi on or off? have it connected to WiFi.
January 28, 20224 yr Author 23 minutes ago, nbs. said: You could use backup/restore before a reset But wouldn't that back up whatever the problem is also?
January 28, 20224 yr 1 minute ago, Fernando said: have it connected to WiFi. turn wifi off and then pair remote
January 28, 20224 yr Author 48 minutes ago, dishuser said: turn wifi off and then pair remote Didn't work. Paired just fine but turned STB off and on again and Bluetooth connection to the remote was gone.
January 28, 20224 yr 3 minutes ago, Fernando said: Didn't work. Paired just fine but turned STB off and on again and Bluetooth connection to the remote was gone. did you turn wifi back on before turning box off?
January 28, 20224 yr Author 36 minutes ago, dishuser said: did you turn wifi back on before turning box off? Yes, I turned the wifi back on then turned off the box.
January 28, 20224 yr Author 3 minutes ago, Fernando said: Yes, I turned the wifi back on then turned off the box. Tried it both way now. wifi on before turning box off and wifi off before turning off box. Same result. Remote loses Bluetooth connection once machine is turned back on.
