January 23, 20224 yr Hi, I don't know if it's only me. But my EPG aren't updating anymore. I clear the data et cache and it's not working too. I use the service of epg.best and the file contain all the information. It was working with the last beta version but not anymore. Do someone have this problem? The image and name are working but not the description of the program, Thx Edited January 23, 20224 yr by philloo
January 24, 20224 yr Author My service isn't expire. I saw that all the description is in the xml file.🤔
January 24, 20224 yr Expiry has nothing to do with epg . Your epg comes from your service. contact them first
January 24, 20224 yr Author I will contact my epg service to see what can cause this problem. I receive the name and icon from the epg service. Why the descriptions arent showing... strange. Cause the in the epg xml file. I see the descriptions 🤨
January 24, 20224 yr Author ok, I check with my old model 3900 and I can say that it's a bug in the beta version.... With the 3900. The epg guide is working... Edited January 24, 20224 yr by philloo
January 24, 20224 yr 13 minutes ago, philloo said: ok, I check with my old model 3900 and I can say that it's a bug in the beta version.... With the 3900. The epg guide is working... try xc api
January 25, 20224 yr Author If i put the direct link of the streaming server. I receive the epg. But I dont wont to use the epg of the streaming server. Its not good. How can i use the link of my epg provider instead in the xc api login?
