I can't seem to find a volume adjustment for Buzztv6 Box
I keeping having an issue, where I have to crank up volume (using a buzz remote) to hear, but then when I switch to other devices my audio is now blasting for those?? I'm assuming there is volume output for the box. Thank you in advance for your help!
I am away from home right now, but there is typically an option in the settings, which is essentially "Force MAX Volume".  Find it in the settings, or buzz utilities and disable it.  Then the box will output variable volume and allow to be controlled by the remote.
ok thank you. I will check it out!
