Portal not supported
Hi
I Haven’t used my xrs4900 for a while but just recently used it again. It updated the iptv app and I got the error portal not supported? Tivimate works perfect I also tried another provider and got the same message.
any help on this?
check to make sure there's no typo error in username/password.
also try url with /c or without /c
The /c doesn’t change the error. My details where working fine until the update to 5.0.956
1 hour ago, NsC0001 said:
I thought that’s what this forum was for?
The forum is to get help but there are  certain issues which buzz have to fix
