December 2, 2025Dec 2 Hello, I have a new BuzzTV Powerstation 6. Running the Buzztv Smart Remote app. It says current Firmware "--". When I click on Update Control Software it shows that Version 7.0 BT-500 Firmware 2024-08-29 is available for installation. I cannot click the Install button using the remote's navigation buttons or mouse pointer. I tried rebooting, force stop apps, clear data of the remote app, tried another remove, and deactivated all of the apps allowed to run in foreground. Button is not clickable. Is there another method to download this update that I can manually install, or some fix for this problem? No BuzzTV operating system updates are available, all installed. Thanks!
December 4, 2025Dec 4 Author Direct Answer: The official place to manually download BuzzTV firmware updates (including BT-500) is the BuzzTV Downloads page. The firmware package for BT-500 version 7.0 dated 2024-08-29 should be listed there. Once downloaded, you can install it via USB following BuzzTV’s update instructions. 🔧 Step-by-Step Guide to Manual Firmware Update 1. Download the Firmware Go to the official BuzzTV Downloads page. Look for BT-500 firmware version 7.0 (2024-08-29). Download the .zip or .img file to your computer. 2. Prepare the USB Drive Format a USB drive to FAT32. Copy the downloaded firmware file onto the root directory of the USB drive (do not place it inside folders). 3. Connect to BuzzTV BT-500 Insert the USB drive into your BT-500 device. Power on the device and go to Settings → Update → Local Update. Select the firmware file from the USB drive. 4. Install the Update Confirm the update and allow the device to reboot. Installation may take 10–20 minutes depending on the size of the firmware. Do not unplug or power off during the update. 5. Verify Installation After reboot, go to Settings → About → Firmware Version. Confirm that it shows BT-500 v7.0 (2024-08-29). ⚠️ Important Notes You cannot revert back once the update is installed. Make sure your device is connected to stable power during the update. If the firmware isn’t listed yet on the BuzzTV site, check their support forum or contact BuzzTV support directly.
December 4, 2025Dec 4 That looks/sounds like an AI generated response adapted from some other firmware update procedure. I don't know about you, but did you try going to the downloads page ? There is nothing to download there, other than the buzztv logo. I tried with 3 different browsers.
December 9, 2025Dec 9 Author Yes, I visited the page and there was no downloadable content. I didn't try the usb into bt-500 because I didn't have the executable to upload the remote software. However, good news--tech support was able to resolve the problem. The problem was not with the installation of the remote update, but that the remote itself had an issue. Unpairing the remote and re-pairing the remote fixed the problem. I was then able to click the button to install the update. Thanks for proposing workaround and potential solutions--appreciate it!
