IPTV does not work properly
This is the same IPTV i use on my U5.
It doesn't play adult channels with timeshift on
I turned on the feature to allow Adults to play as favorites
It will work for 2 channels and then i get a timeshift error stream not found
Timeshift does NOT work with all streams.
Are you using TS or HLS streams ?  And if your drive is toast (from the sounds of the other post you made - in the wrong section), then obviously timeshift will not work.
