August 17, 20251 yr Is it possible to remotely connect to someone box to configure adjust add server portal settings ?
August 17, 20251 yr Pretty sure most boxes come with TeamViewer installed. You can use that. Butting adding portal and stuff on Buzz boxes is so simple. Even guided seniors (non-tech savvy) through the task and it wasn't that difficult.. Edited August 17, 20251 yr by Emporium
