July 2, 20251 yr Hello everyone, I purchased the P6 about 4 weeks ago. I am currently using the IPTV Editor program to customize my lists and utilize the auto-updater EPG data. When I enter the M3U and Xtreme API on my P6 I encounter a connection error. The P6 cannot connect to the service. The same credentials work with Tivimate and four other IPTV apps with zero issues. Does anyone have an idea why the IPTV Editor links will not work on the P6? Should I be adding the credentials to the "live TV" option or in the Buzz TV 5 app? Thanks in advance for your help.
July 2, 20251 yr Are you 100% sure that there are no accidental spaces in the m3u link when you type it in ? Sometimes the Android keyboard can have a tendency of adding a space after every "." which if you are not looking at the entry field it is easy to miss. Have you tried using the BuzzTV 5 app to see if it works ? The BuzzTV 5 app was added there to give users a choice using the previous version of BuzzTV, since when the P6 came out originally, BuzzTV 6 was still missing a few features. You have nothing to lose by trying it with BuzzTV 5, just to see if it works. I have not used IPTV Editor, but I do have a bunch of my own M3U lists, which I host on my pastebin account and I have no issues with any of those. And XC definitely works, since my main server uses XC and I have zero issues with it. Edited July 2, 20251 yr by Emporium
