October 19, 20242 yr J avais un xrs 4900 et j ai acheter BuzzTV X5 SuperSport j ai pris mon disque dur externe WD et je les mi sur le x5 et ilme dit qu il est ejecter je les formater et toujour ejecter pourquoi qu il ne fonctionne pas
October 19, 20242 yr I just tried my WD 2TB "My Passport" and had no issues. Also tried a 2TB WD "My Passport ULTRA", also no issues. I also tried with a Seagate Backup Plus Slim 1TB external and that would always give me "ejected". I connected it to my Windows PC, and I opened a command prompt and then started DISKPART. From DISKPART> prompt, I did a "LIST DISK" to identify my USB drive. Then I did a "select disk 3", since that was the disk number of my USB disk. The did a "LIST DISK" again to ensure that DISK 3 was selected. Then I did a "clean" to wipe everything from the disk (including MBR). Ejected disk, then went into Disk Manager (diskmgmt.msc). Re-connected my USB disk. Then it show up as "not initialized" (which is good). Right click the not-initialized box on the left, and select "initialize disk" and choose as "MBR" (not GPT). Then right click the allocated space, and select to "create a new Simple Volume". And when you get to the filesystem type, don't format as NTFS, select exFAT. Eject drive, plug back into X5 SS and it works perfectly again. PS: Please post in the correct section for any further support. This section is for "AR200 - remotes".. Edited October 19, 20242 yr by Emporium
