August 13, 20242 yr Hey guys the ethernet port on my box is not working I tried the same cord on a different device and it worked so I know it's not the cord is there anyway you guys can do to help me out
August 13, 20242 yr 29 minutes ago, DRAG00N519 said: Hey guys the ethernet port on my box is not working I tried the same cord on a different device and it worked so I know it's not the cord is there anyway you guys can do to help me out have same problem at least wifi worx
August 13, 20242 yr i am using ethernet without issue, and i did nothing other than do todays update. i have wifi turned off, but it did default to ether
August 13, 20242 yr Author 8 minutes ago, sts41 said: i am using ethernet without issue, and i did nothing other than do todays update. i have wifi turned off, but it did default to ether It's not a problem on every box my friend bought the box as well and does not have the issue
August 13, 20242 yr Author 48 minutes ago, dishuser said: have same problem at least wifi worx True it's not the worst thing in the world but if it can't be fixed, I'd be fairly disappointed I really prefer to hardwire my android boxes
August 13, 20242 yr 3 minutes ago, Chris1 said: I can't even get my iptv servers to work keep getting error code what does that have to do with ethernet?
August 13, 20242 yr 2 minutes ago, DRAG00N519 said: True it's not the worst thing in the world but if it can't be fixed, I'd be fairly disappointed I really prefer to hardwire my android boxes the only reason I ran ethernet was because my 4900 would drop wifi after 3-5 hours it could be a bad port
August 13, 20242 yr Author 27 minutes ago, dishuser said: the only reason I ran ethernet was because my 4900 would drop wifi after 3-5 hours it could be a bad port I'll be honest I had the same ethernet issue on my 4900 and the staff try to help me with the issue but nothing worked so I returned it and they gave me another one and the new one had the same issue at the time that was a dealbreaker for me the only reason the ethernet port wouldn't be a dealbreaker for me this time is the box was expensive so I'll just deal with it if I have to, I'm hoping that's not the case though
