August 9, 20242 yr Numerated items above: Powerstation box HDMI Cable Power supply Cable for power supply Silicon plugs (Green/Yellow) to plug any unused ports on the box, should you wish. Energizer AA batteries (as usual, no cheap batteries here) extra retaining rubber plug for NVMe Buzz BT500 remote Connectors on both sides of the box Front side: USB3, USB2, and USBC along with the green power button with the buzz logo on it. Back side: Power connector, TF (MicroSD), Optical connector, HDMI and gigabit Ethernet port. (Not pictured) There is a small LED bar on the top of the box (under one of those hex patterns) And it is Green when power on, Red when in suspend (I assume will be same when powered off), and nice touch, you can turn the LED BAR off all together from within the menus. Cover comes off the bottom, to reveal an NVMe slot. There is already a single rubber retainer in the 2280 size location. However you can surely install 2230, up to 2280 NVMe drives, and either move the existing plug to support it, or use the spare one if you are using something smaller than a 2280. Power supply is a universal 100-240V, 50/60Hz with c(UL)us certification markings. Unlike previous Buzz power supplies, this powersupply has a separate 2 pin power cable going to it as you can see. No ground and does not take up more than one plug on an outlet or any power bar. I received the North American version so the power cable has the standard NEMA plug on it, but for other countries, I assume buzz will either include a universal plug adapter, or a different power cable to connect to the power supply. The included power cable connecting to the power supply is about 2.5ft long, and the power supply with the cable going all the way to the barrel is about 3.5ft long, giving you a total length of about 6ft. For those who care about the power supply other specs, it is rated as 12V 3A. The barrel connector at the end has a 5.5mm OD, 2.1mm ID (pulled out my calipers to confirm) and is Center Positive. This box is quite a bit bigger than other buzz boxes. It measures roughly 6 inches (~15cm - front to back) x 5 inches (~ 13cm side to side) x just over 2 inches high (~5cm). measurements are approximate
