December 14, 20214 yr Mr.NBS can you please give me a tutoring of how you format your hard drive into your Buzz 4900 box how do you format the drive please tell me how to do it I have someone format a drive for me on a computer to ntfs and when i put it into the 4900 under storage it is showing me new volume is safely ejected and i cannot access the drive so can NBS or anyone else tell me how can i use the 4900 box to format the drive .
December 14, 20214 yr Author The guy say he format it to ntfs but the 4900 is showing me new volume is safely ejected when i go to storage can you tell me how to format it on the 4900 box itself where on the box i should go to format it?
December 14, 20214 yr device preferences ,storage ,removable storage .click on your drive,set up as device storage, format
December 19, 20214 yr Author On 12/14/2021 at 5:15 PM, nbs. said: device preferences ,storage ,removable storage .click on your drive,set up as device storage, format
December 19, 20214 yr Author My 4900 is now recognize my HHD drive now but when hit the record button how do you know when the program is recording, and where do you go to play back a recording can someone explain it to me.
December 19, 20214 yr 3 minutes ago, mr man said: My 4900 is now recognize my HHD drive now but when hit the record button how do you know when the program is recording, and where do you go to play back a recording can someone explain it to me. it will show rec in top right click pvr button on remote to play it
