February 10, 20242 yr Hi. New to Buzz TV i’m trying to pair my remotes. I was able to pair one Buzz box and TV but hen I try to put the BT250 in to learn mode I get a solid blue light. ‘any help would be appreciated.
February 10, 20242 yr Is this 2 different remotes, or the same remote ? Pretty sure the remote will only pair with one box. Pair with a second box and it will no longer connect to the other box. Have you checked out the manual for the BT-250 ? To start pairing process, you need to press and hold the "OK" button and "VOL -" for 3 seconds. hxxps://buzztv.com/wp-content/uploads/2023/03/BT-250_Manual_V1.1.pdf Keep in mind that for TV functions to work, CEC needs to be enabled and TV needs to be compatible also. If the CEC does not work with your TV, you can still program the Basic TV functions (power, source, vol+, vol-) with the IR learning functions (using your original remote to then have the bt-250) learn the IR codes to use. It is IR, but then again, most TV remotes are also.
