How to setup universal remote ro xpl3000
If you are using something like a Logitech Harmony remote, at least Logitech does have the xrs4500 (and xr4000) in their database.  The IR codes are the same for Buzz products so you should be able to get 99% of it working.
Now, for Bluetooth pairing, that is a different story.
If you are using some old Radio Shack RCA or other "universal" remote, then good luck.
