November 29, 20214 yr I'm a bit of an IPTV newbie, and using my BuzzTV XRS4500Max box and the native live TV, VOD and EPG app to view. My program guide is almost always wrong or out of sync with what's showing at a given time. Is there a way to have it update properly? I've tried other viewing apps and they work fine, except then the remote buttons (LiveTV, Guide, Last, etc.) don't work. Is there any way to get the native LiveTV and EPG app to work properly? Thank You!
November 29, 20214 yr go to menu/account info what time zone shows? then go to menu/configuration/epg time offset and match it
November 29, 20214 yr Author Thanks, but time zone is correct. The same show listed from 3:30 pm (football game) still shows as what's playing at 10 pm. It's not displaying updated info for what's showing at different times. As I noted earlier, I've tested a couple of different viewing apps and they work fine. It's only the native BuzzTV viewing apps that are wrong. Thanks!
November 29, 20214 yr 59 minutes ago, Mike said: Thanks, but time zone is correct. The same show listed from 3:30 pm (football game) still shows as what's playing at 10 pm. It's not displaying updated info for what's showing at different times. As I noted earlier, I've tested a couple of different viewing apps and they work fine. It's only the native BuzzTV viewing apps that are wrong. Thanks! you went to menu while in live tv?
November 29, 20214 yr 4 hours ago, Mike said: Thanks, but time zone is correct. The same show listed from 3:30 pm (football game) still shows as what's playing at 10 pm. It's not displaying updated info for what's showing at different times. As I noted earlier, I've tested a couple of different viewing apps and they work fine. It's only the native BuzzTV viewing apps that are wrong. Thanks! When in Live TV Press the Menu button Go to Configuration Adjust the EPG Offset to +7 Hours Wait for the EPG to clear, about 2-3 minutes Then re check the EPG Am only guessing its +7, you might have to figure out the correct adjustment yourself.
November 29, 20214 yr epg offset is easy to figure out it shows you what timezone server is in under account info
December 2, 20214 yr On 11/29/2021 at 3:20 PM, dishuser said: epg offset is easy to figure out it shows you what timezone server is in under account info Good Morning, I can’t seem to find that info under account info . I do see the Mac, expiry and what time it expires at which is midnight including the latest version of the buzz software . both services expire at midnight but different dates . regards
December 2, 20214 yr 1 hour ago, nbs. said: Not all servers have that info in account info I think it's mac that don't show it
