November 4, 20214 yr Output Resolution: 4K (3840 x 2160) CPU : Amlogic S905X3 64-bit quad-core ARM® Cortex™ A55 GPU : G31™ MP2 RAM: 2GB DDR3 Storage: 32GB eMMC Operating System: Android OS 9 Pie --------------------------------------------------------- WIFI: 2.4GHz / 5GHz Dual-Band 2X2 Wifi LAN: Ethernet 10/100 BT: 5.0 -------------------------------------------------------- Video decoder : 4K@60fps, VP9, H.265(HEVC) , H.264(AVC, MVC) , Real , MPEG1/2/4 , Video Format : TS , MKV , FLV , MOV , AVI , RM , MP4 Audio Format : MPEG-1 Layer 1,2 , AAC-LC , HE AAC V1 Image decoder : JPG , BMP , GIF , PNG Support Language : Global ---------------------------------------------------------- Length : 10.5cm Width : 10.5cm Thickness: 2cm Color : Black --------------------------------------------------- USB2.0 : 1 USB3.0 : 1 MicroSD: 1 Power Interface : 1 Optical Audio : 1 HDMI 2.0 (CEC) : 1 10/100 LAN : 1 ---------------------------------------------------- Type : 5V 2 Amp Adapter ----------------------------------------------------
June 15, 20224 yr I bought this unit. Comes withIR-100 remote. I can’t seem to get the air mouse to function at all. It’s like the stub is not reading it
June 15, 20224 yr Thanks, I can move it that way but it won’t scroll Netflix options. I was told it’s not a Bluetooth remote and it will not work properly on Air mouse. But thanks anyway
June 15, 20224 yr I bought the BT100 remote which has Bluetooth and comes with a little usb thingy that plugs in to the STB to work the Airmouse. So I’m using 2 remotes.
June 15, 20224 yr Yes thank you. I realized the old one is ARQ 100 and it operates the air mouse perfectly on my stb. Thank you everyone for your responses. Love this forum Edited June 15, 20224 yr by W.Barber
June 15, 20224 yr 41 minutes ago, W.Barber said: Yes thank you. I realized the old one is ARQ 100 and it operates the air mouse perfectly on my stb. Thank you everyone for your responses. Love this forum only the arq's have air mouse
