November 2, 20214 yr I installed an SSD drive into the buzz TV XRS 4900. When I look at storage it shows me that it's there but it says it has been safely ejected. Can anybody tell me what I'm doing wrong? Appreciate any help.
November 2, 20214 yr 1 hour ago, Iceman said: I installed an SSD drive into the buzz TV XRS 4900. When I look at storage it shows me that it's there but it says it has been safely ejected. Can anybody tell me what I'm doing wrong? Appreciate any help. Where did you format it, on the box or on a PC? Try formatting it on a PC first, to NTFS Then plug it back into the box.
November 2, 20214 yr Author On the box. Now it recognizes it. But when I go to record using buzz TV's live tv player. It only gives me the option of internal storage . There's no way I and switch it over to the SSD drive
November 2, 20214 yr 4 minutes ago, Iceman said: On the box. Now it recognizes it. But when I go to record using buzz TV's live tv player. It only gives me the option of internal storage . There's no way I and switch it over to the SSD drive You format it as Internal Storage or External Storage?
November 4, 20214 yr On 11/2/2021 at 6:45 PM, Iceman said: External. Format it on a PC first to NTFS Than Format it on the box as external storage It should work after doing this.
November 5, 20214 yr On 11/2/2021 at 6:32 PM, Iceman said: On the box. Now it recognizes it. But when I go to record using buzz TV's live tv player. It only gives me the option of internal storage . There's no way I and switch it over to the SSD drive Click the PVR button on remote and change storage right at the top.
