October 24, 20214 yr Had the unit on but was watching cable on another HDMI input, suddenly the XRS4900 led went to flashing red and then the TV switched inputs on it's own to the XRS4900. Black screen, wont turn on, won't reset after power unplug, red light keeps blinking, WTF? Edited October 24, 20214 yr by Diez
October 24, 20214 yr 10 minutes ago, Diez said: Yes tried 3 times Unless someone else can come up with an idea unfortunately you will have to contact buzz to do a rma use the contact us http://buzztvglobal.com Edited October 24, 20214 yr by nbs.
October 24, 20214 yr 7 minutes ago, Diez said: sonova... fortunately buzz have great support You would be out of luck with a lot of other brands
October 24, 20214 yr Author We shall see. Left unplugged overnight and now when plugged in it's completely dead
November 3, 20214 yr Author So an update after sending my XRS4900 back to Buzz. Turns out if you encounter a flashing red front light it indicates your AC power supply has failed. My unit checked out ok but they are replacing the AC power cable
November 3, 20214 yr we thought it was possibly a power supply but it still has to be checked out Glad it worked out for you
