October 22, 20214 yr So I just got this box yesterday and was setting it all up. I get it up and running and I was trying to put info in from the remote and it would do anything. I ended up changing the batteries thinking maybe that was the issue. No change. The I Lu time it works is if I’m no more than 1ft away maybe… not sure what is wrong or how I can fix
October 22, 20214 yr Author 3 minutes ago, Maurice said: So I just got this box yesterday and was setting it all up. I get it up and running and I was trying to put info in from the remote and it would do anything. I ended up changing the batteries thinking maybe that was the issue. No change. The onlytime it works is if I’m no more than 1ft away maybe… not sure what is wrong or how I can fix Edited October 22, 20214 yr by Maurice
October 22, 20214 yr Author No. But after I saw what you asked I found out how to pair it and it’s working!!!! Thanks!! I guess I thought that if it was working that it was already paired. But I’ll have to get the code for my TV so I can pair the remote with the tv
October 22, 20214 yr 2 hours ago, Maurice said: No. But after I saw what you asked I found out how to pair it and it’s working!!!! Thanks!! I guess I thought that if it was working that it was already paired. But I’ll have to get the code for my TV so I can pair the remote with the tv instructions are on the back of the remote also how to section has info
