RE: How to use Catchup on XRS4900
Hi I am trying to use Catchup but it doesn't work on the XRS4900 is there a setting I need to enable to get Catchup to work?
Catchup I tested and is working on Smarters IPTV Player.
Can you help me get it to work on the XRS4900 please.
Yes.
I see the Catchup Icon on the channel but when I click on the the shows in the EPG that are not live I get Media Format not supported.
When I go into the Single EPG when I click on previous shows in the Single EPG it just circles.
In the Smarters IPTV it works perfect and let's me Pause, FF and RW.
So I know it works
