Ethernet connection
Good day. Unable to connect Ethernet. I connected a usb hub with Ethernet connection. Plugged cable plus usb stick and mouse usb.  Recognized stick any mouse. Did not acknowledge cable.  Tried using hub with Ethernet to power. Same result.   Does The same.  Read that must use Buzztv connector.  If connected to Ethernet then how do I add/read  a usb stick or add a usb mouse?  Buzz needs to add usb hub to their connector or tell how Todo it.  Support does not acknowledge enquiries.  Thank you.
Support will answer  It might not be as fast as you like but they will answer
You can also pm allaboutbuzz
