XRS4900 overheating probleme
Hi
my new XRS4900 is over heating and stops working.
no heat source near or around the box. Please help me .
Thank you
Stephane
I have had mine on pretty well 24/7 for the last three months with no issues Its only warm to touch
Thank you for the info 👍
36 minutes ago, dishuser said:
do you have a drive installed?
No i don’t
45 minutes ago, DRAG00N519 said:
I have mine on all day long with no issue at all
take a outlet tester and test to make sure your outlet is correct. its not hot/nutral/reverse.
or just flip adapter around to see if issue goes away
Will try.
thank you
I will get a tester and Check
