1. Select Settings
2. Select Device Preferences
3. Scroll Down and Select Sound
4.  Click on System sounds
By Default The System Sounds is always On, by clicking OK on your remote you will turn off the Sound notification.
5. Press Back till you are in Main Screen
Enjoy!
