April 28, 20233 yr I have 3 buzz tv boxes side by side running on 3 separate tvs but when I change to a channel on one box it changes the others. I was wondering if there is any way of changing any code so the remotes will work separately?
April 28, 20233 yr 17 minutes ago, Luis said: I have 3 buzz tv boxes side by side running on 3 separate tvs but when I change to a channel on one box it changes the others. I was wondering if there is any way of changing any code so the remotes will work separately? nope do what my bar does place cardboard shells over the boxes remove when you want to change channel Edited April 28, 20233 yr by dishuser
April 28, 20233 yr Author Oh ! Ok . I tried using electrical tape to block the front of the box but it didn’t work. But I didn’t try that.
