XR4000 Ethernet Bandwidth
Running my XR4000 hard wired to gigabit router with 150mbps service, every device I have is getting 130+Mbps service (wifi) and tested my laptop with ethernet, the same cable(s) for box and I get 140+Mbps,  but the box is only showing me on speed test.net 50+/- Mbps is there something I'm missing? Is this normal?
XR 4000 ethernet port is only 10/100
So maximum speeds it would ever get is about 95mbps
I'd like to even see that... Is there something in settings (developer) or standard I could do?
Edited by STR33T11
3 hours ago, allaboutbuzz said:
No there aren't any settings for it
Are you running the latest Update?
Most recent correct
Yea  I'm just going to upgrade thank you prompt response ¯\_(ツ)_/¯
Edited by STR33T11
