November 11, 20205 yr Anyone notice the sound loss lately on some severs using the buzz xr 4000 my other boxes not related to buzz are fine Freinds buzz xr 4000 same also
November 11, 20205 yr 1 hour ago, Rinny1 said: Anyone notice the sound loss lately on some severs using the buzz xr 4000 my other boxes not related to buzz are fine Freinds buzz xr 4000 same also Which Player are you using when this happens Default or Secondary?
November 11, 20205 yr Author Default player just loosing sound secondary player will lock up with the circle ⭕️ 12 plus boxes all different ISP just weird lately been awesome this started 5 days ago
November 11, 20205 yr seems this is somehow server related but maybe not totally. With a certain server, the sound will drop if and when the channel has a glitch (a short freeze for example). After the freeze or other glitch has gone away, the sound is gone. The sound comes back with a channel zap (change channel up and then back). Seems this only happens with the 4000 model thou (s what Rinny has told me) and not other boxes with same setup. I am working with Rinny in private, to test some things. I will be testing how other boxes act and how this 4000 I have here acts (with that certain channel access). I have not seen the issue here on this 4000 but my channel access is not the same as what Rinny has, so once I get that handled, then testing will resume.
November 12, 20205 yr I'm having a similar issue but only on some channels. On my Buzz 3000 box, I can watch BBC Canada without any issues but on my XRS4000 box, it has no sound.
November 12, 20205 yr 17 minutes ago, ledfoot said: I'm having a similar issue but only on some channels. On my Buzz 3000 box, I can watch BBC Canada without any issues but on my XRS4000 box, it has no sound. On 4000 when you're watching that channel with no sound Can you press the Green button The Subtitles and Audio menu will appear Under Audio do you have another option besides just disabled?
November 12, 20205 yr Author I tried everything it’s a buzz 4 app related! all xr 4000 xr 4500 testing all have the same problems loosing sound
November 13, 20205 yr 21 hours ago, allaboutbuzz said: On 4000 when you're watching that channel with no sound Can you press the Green button The Subtitles and Audio menu will appear Under Audio do you have another option besides just disabled? This resolved my issue. I had to select "Track 1" for this channel under options. It's strange that it happened to this channel only. Thank you.
November 14, 20205 yr 7 hours ago, ledfoot said: This resolved my issue. I had to select "Track 1" for this channel under options. It's strange that it happened to this channel only. Thank you. No problem Glad it works now.
November 14, 20205 yr Author Buzz 3000 fine for sound also just the buzz4 app having problems other boxes tested no problems different brands some 6 years old to brand new no sound loss on that server we talking about
