LAN & WiFi speed
Hi
Not sure if my issue started after latest update but I noticed my Lan has gone down to 75 to 80 mbps it was 800+ I have a 1g fiber connection. My router says the xrs4900 is connected on a 1g line but on Speedtest app it’s way down. Also if I use 5g WiFi it’s down at 30 and strangely when it tries to test the WiFi upload the app says no connection?
any help/advise would be appreciated.
check your settings on your speed test app. make sure to pick right servers. if possible try to reinstall or see if new version of that app is available.
