Mini remote
I have installed 2 AAA batteries and the remote wont function and just flashes red.  Any suggestions to make it work.  Thank you
if it has a none stop flashing,  please take the batteries out, and try to press all the buttons to make sure none of them are stuck under the shell, then install the batteries back. If you are still having the same problem that means your remote quit.
please purchase another remote for your XPL1000
best remotes are
- Buzztv ARQ 100
- MyGica KR41 Air
- MyGica KR301
- MyGica KR303
