May 17, 20224 yr I would love to cut the cable TV, Now I need some advice of what I should get , WIFI-Internet , how strong or Mgb do I need , Do I need to get twice IPTV FOR 2 buzz tv boxes, And is there any help Available if I have problems with connecting the TV Boxes, I would appreciate a little note from you, to led me know , which boxes are the right ones , and so on, and so on !!
May 17, 20224 yr Author I need help with cutting my cable and Wifi , also do I need a advice which of your TV Boxes should I get, how much Mgb should I require to run my boxes ,do I install 2 IPTV FOR MY 2tv or because thy are having a cable splitter would 1IPTV be enough!! would help also be available for any connection help?????????? Love to hear from you ! Best way will be by phone if possible, I’m to old for this typing 🙏 Sincerely M.H.
May 17, 20224 yr it depends on what you plan on using boxes for you can see the lineup here https://buzztvglobal.com/ for iptv you need unlimited bandwidth and a speed of around 10 mb/s
