April 30, 20224 yr can you change the background on a XRS4500 running buzz4?...i just purchased the box and cannot find where to add/change backgrounds....
April 30, 20224 yr have you checked in My Apps > Files > Images. I think pictures saved in images will give you an option to add/change background.
April 30, 20224 yr 5 hours ago, Raidersam67 said: can you change the background on a XRS4500 running buzz4?...i just purchased the box and cannot find where to add/change backgrounds.... you need to use media player or media player 2 settings/change background
May 7, 20224 yr Author On 4/30/2022 at 5:21 PM, dishuser said: so how did you make out? i got backgrounds to work...but only on media player and media player 2....
May 7, 20224 yr 7 hours ago, Raidersam67 said: i got backgrounds to work...but only on media player and media player 2.... that's because you don't have buzztv 5
