April 23, 20224 yr I’ve had the E2 SE box for about a month now, and my remote was working just fine. All of the sudden it won’t work. I’ve changed the batteries, I’ve restarted the box, I followed the instructions and I cannot figure out what’s going on. When I press the buttons on the remote the red light flashes on the remote but nothing happens on the tv. I can’t get passed the first page. Does anyone know what I can do to fix this? Or do I need a new remote?
April 23, 20224 yr Author 1 hour ago, nbs. said: Also look at the end of your remote through the phone camera Does it light up? Yes you can see the red light inside
April 23, 20224 yr You can't even do a hard reset without a working remote Email buzz and see what they want to do
April 23, 20224 yr do you have any usb or bluetooth dongle, sd card or anything external connected to the box? if yes remove them, disconnect and reconnect power and wait for box to come up then check to see if it works. 🙂 Edited April 23, 20224 yr by Ryu
