Device not Authorized
Hi guys, just received 2 XRS 4000's  from Amazon.
Started the Set Up on the first one, and during the Checking for Updates, it pops up "Device not Authorized"
Then it says to contact cs@buzztv.com with the serial number. I can send it to someone that can help. please.
Anything I can do before Monday?
I have 4 other Buzz Tv products, none did this.
Thank you,
Mark7
i had that happen a few times
Pm allaboutbuzz with your server id
did you reboot a couple of times?
sometimes that helps
Like a Power Reboot? Pull power cord while it is running?
Thanks,
Mark7
Thank you Allaboutbuzz and NBS for your help. XRS 4000 is downloading.
Number 5 and 6 Buzz Boxes for the stable/house !!!!
Thanks,
Mark7
Thanks,
Mark7
I just meant a normal reboot using power button
Glad it's worked out
  • 4 weeks later...
Im hoping someone can help.  I purchased an XRS4500max and it says that my device isnt authorized.   I tried re-booting but still givong me the authorization error.
You can try a couple of times
If still not working email buzz with your device id
Cs at buzztv.com
2 minutes ago, nbs. said:
It did take me 3 4 times once
Other time I had to wait
Thanks for your quick response. Unfortunately I have to wait.  Thanks for your help.
