September 18Sep 18 Hello, We have a new issue with our box, that has has been happening the past month. When watching a stream on Kodi, every 10 minutes or so, there is a significant drop in frame rate (video becomes "jerky"). It sometimes recovers on it's own, but usually a pause-play will fix it. Here are some details that may (or may not) be relevant: When the stream starts playing, the screen will flash for a second (as if it was changing frame rate?). The TV has: max refresh rate 125Hz, interpolation (creates intermediate frames). BuzzTV display mode is at 59.9hz Auto Frame Rate Settings: Enable AFR for Apps=OFF, Always use Exact Framerate=OFF. Any idea what may be causing this issue, and how to fix it? Thanks in advance!
October 21Oct 21 Author On 9/18/2026 at 10:00 PM, dishuser said:try it with auto frame rate onThank you, this worked. But I noticed after several hours, auto frame rate switching stops working. A box restart will fix the issue, but is there a way to extend how long auto frame rate switching lasts?
