Recording Issues with Buzz TV 6
My recordings work fine if I press the record button and stop manually. But when I try to do a scheduled recording I put everything in correctly. It seems to start correctly, but after the system should have ended recording, I turn on the tv to find it is still recording. When I manually stop the recording process the whole thing is deleted and nothing is there. Why does it not stop recording when scheduled, and why when I stop it manually is there no program there? Thank you.
No one I know is having this issue. You recording to internal or external?
You havnt posted any info to allow people to help you not even the model
Try saving your settings and server info and do a reset
