no sound sometimes
Ive noticed a few times loss of sound, i noticed it when i watching a number of youtube videos via the YT app. the only way to get sound back is to reboot the box by pressing power for a few soconds.
trying to adjust the volume level or mute , has no effect.
Its not a big problem for me as i can restart the box, but it might be of some use for the developers.
When you go to settings, and then device preferences and scroll down to decode & bitstream and click on it under audio device which one of the three options is selected?
That would depend on your hardware
Correct but I find when using HDMI Passthrough some apps work, and some don't  when I use the decode option everything seems to be fine I was just wondering if their device is set to HDMI Passthrough by default, and that might be the issue
I had problem with sound on 1 of my apps, went into setting of the app and turned off Hardware-accelerated decoding and then selected HDMI passthrough and had no problem. I do not us the YT app, but check in the app settings, might be something there that might work.
