Catch up not working
Catch up is not working. Doesn’t do anything. Previously, I’ve had it say file not supported or streaming not available.  Currently when I try to click on a program to watch that isn’t live it just pauses the live stream and nothing happens.
I’ve tried multiple channels
Firmware V20230815
iptv version 5.0.935
live set to Primary, tried back up
not sure what the media player is.
first buzz tv for me and first time ive had a pronged issue
Yes it does.
it is also channels i routinely use for catch up
Yes. Pick the channel then scroll for example the F1 race from earlier today. Click on it, which would normal load the program.
4 minutes ago, Scott said:
Unsure how i find that out
settings/configuration/stream format
also are you using primary player?
I have no issues using catchup
but that relies on the server storing past programs
Stream format not an option that i can find.
i never have had issues using catch up in the past
Always.
had this for about a year. Never made any changes to anything
7 minutes ago, Scott said:
Always.
I'll have a trial account for mac set up on the service I use to determine if it's a buzztv or service issue
