XRS 4900 Display settings
Hi
my box was in storage for a while as I was remodelling the house. I now have my system setup again but noticed the display setting are lost each time I start up.
I have tried changing the hdmi cable but change. Any help would be appreciated.
thnaks
Neil
should post in 4900 section. what display seating are you talking about, display and sound, hdmi-cec, and power, screen position? need some more information. what app version do you have? post some info.
Hi you can select resolution in settings then display. But my system defaults back to a low resolution after a power down
Yes I tried that but is does the same. After power down it goes to 480 then inhale to switch it back to 1080 toggling the auto switch
4 hours ago, NsC0001 said:
Yes I’ve just done a backup so will try reset
did you transfer the backup with a file manager?
No I used the backup option in config.
i then selected internal memory and did the reset🤪 So lost it all with the reset. The rest didn’t help as I still have the same issue.
try turn off CEC settings if you have them ON and then see what happens
what settings is your TV set to? also what brand is your tv is?
Its a Samsung 7 series (58)lcd Anynet+ is set to on as I also have a Samsung soundbar
you have to transfer from internal to stick
then reset
try to turn on cec on your box and turn virtual switch off then try. I had one time similar issue with 4900 and Samsung 5 series and I turned off virtual switch fixed me issues. you can try that as well let us know
Thanks for helping.
its something to do with my Samsung tv. I switch to hdmi port 2 and that fixed it. Can’t find anything in tv settings that would do this, but it working now
