power light
Not sure why but my 4500 works well and still does , the only difference is when i power down the unit the green light stays on . It does not turn red anymore . It does power down and is on stanby ,but the light does not turn red anymore .  I tried a few things but to no avail. any help appricited , thanks .
im talking about the light on the front of the box ,and im using wifi
Sorry i mean the blue light stays on . CEC are , cec switch ;off ,one key play ; off, device auto power off ; on , auto change language ; off.
mine stays blue if I use suspend
I tried a few things with cec but nothing seems to work . i figured out that if i am hard wired with it the light work properly but if i use wify the light does not go red when i turn unit off . ??
