Red Light
When I select the source the box is on it doesn't wake up. The light stays red and what's strange is when I selected the source it was on today the TV show cames on but I can't use the remote for the box. Only the volume works and the light doesn't turn blue. What can I do to fix this?
9 minutes ago, Redhusker24 said:
Yes I can but what do I change?
Maybe cec settings?
turn off virtual cec switch from CEC settings and see if that helps. 🙂
