November 19, 20196 yr How to set by default on VOD listing ...Newer Episodes on top by default . ( i.e default list 9-0 instead 0-9 ) no extra button to press.
November 19, 20196 yr while you are in VOD, if you press Green button on your remote it should do the job for you.
November 19, 20196 yr Author that's right, but it would be great if by default the new episodes on top of the VOD list without pressing Green Button and Then choosing (9-0)
November 19, 20196 yr 1 hour ago, G2P said: that's right, but it would be great if by default the new episodes on top of the VOD list without pressing Green Button and Then choosing (9-0) changing the default new episodes list will make some people happy and other people unhappy. this is why we added the green button option. we can look into an option to set all episodes to show default 9-0 vs 0-9
November 19, 20196 yr Author i think most people watch latest or current episodes ,and only some who missed or started late may use from 0-9 thanks to considering an option Edited November 19, 20196 yr by G2P
November 20, 20196 yr Author 1 hour ago, G2P said: i think most people watch latest or current episodes ,and only some who missed or started late may use from 0-9 thanks to considering an option OR like in XPL3900, Scroll up will take you from episode one to last in backward will be great for all (no need of 0-9 or 9-0)
November 22, 20196 yr On 11/19/2019 at 8:13 PM, G2P said: OR like in XPL3900, Scroll up will take you from episode one to last in backward will be great for all (no need of 0-9 or 9-0) unfortunately its not easy to support this feature on Android 9. We're working on a solution at the moment.
December 5, 20196 yr On 12/3/2019 at 6:20 PM, G2P said: any updates reverse VOD list if you want to use the beta pm with your serial number. this feature is added on the beta
December 6, 20196 yr Author 8 hours ago, Stugots said: if you want to use the beta pm with your serial number. this feature is added on the beta Thanks for updating in Beta the VOD list listed backward (Last episode on Top)🙏
