August 22, 20215 yr I downloaded M3U file using downloader app but when I went to the server and I put the M3U file link after connecting "Loading channel list..." has been showing for hours but it works with VLC app. When I check for M3U in App Installer it's not there. Thanks in advance for any suggestions.
August 23, 20215 yr Author Thanks Ryu for the reply. Finally it works but EPG not working. How to set it up? Thanks in advance
August 23, 20215 yr glad you got it. for epg you need to enter epg url. I would use XC option with username and password instead of m3u option if possible. with this option you enter url, username and password and thats it. I think its better option.
August 29, 20215 yr On 8/23/2021 at 4:05 PM, Ryu said: glad you got it. for epg you need to enter epg url. I would use XC option with username and password instead of m3u option if possible. with this option you enter url, username and password and thats it. I think its better option. Remember there is issue with buzz not reading m3u file but I agree xc login option is better.
August 29, 20215 yr 48 minutes ago, Maestro701 said: Remember there is issue with buzz not reading m3u file but I agree xc login option is better. absolutely 🙂
August 29, 20215 yr 6 hours ago, Maestro701 said: Remember there is issue with buzz not reading m3u file but I agree xc login option is better. A lot of IPTV companies have already stopped allowing customers to use M3U lists but now they're also not allowing customers to use a MAC address because both those portals are security risks so the xtreme codes portal is absolutely the way to go
August 29, 20215 yr 10 minutes ago, DRAG00N519 said: A lot of IPTV companies have already stopped allowing customers to use M3U lists but now they're also not allowing customers to use a MAC address because both those portals are security risks so the xtreme codes portal is absolutely the way to go all 3 are at risk of being hacked
August 29, 20215 yr 15 minutes ago, dishuser said: all 3 are at risk of being hacked by no means am I trying to say that the xtreme codes portal is 100% secure I'm just saying that a lot of companies are moving away from the other two
August 29, 20215 yr 2 hours ago, DRAG00N519 said: by no means am I trying to say that the xtreme codes portal is 100% secure I'm just saying that a lot of companies are moving away from the other two a site I belong to posts dozens of xtreme codes every day for over 3 years now
August 29, 20215 yr 1 hour ago, dishuser said: a site I belong to posts dozens of xtreme codes every day for over 3 years now Yeah when it comes to IPTV nothing is totally secure it comes with the territory and you just have to be as careful as you can
August 31, 20215 yr On 8/29/2021 at 3:05 PM, dishuser said: all 3 are at risk of being hacked That's what I thought
