June 24, 20215 yr I would like to ask user of the 4900 if you are using 2 or more servers and you have favorites list set up if you click on the short cut on the favorite list will the box automatic switch to the respective server that that channel is on or do you have to go into server setting at all time when you want to change server.
June 25, 20215 yr im not sure if I understood you correctly but my box goes to last server I was connected.
June 25, 20215 yr 2 hours ago, mr man said: I would like to ask user of the 4900 if you are using 2 or more servers and you have favorites list set up if you click on the short cut on the favorite list will the box automatic switch to the respective server that that channel is on or do you have to go into server setting at all time when you want to change server. like I told you on other site you have to switch to other server favourites are stored server by server not as a whole
