XPL 3000 will not update
Please help, I have an XPL 3000 that will not update, I tried resetting it back to factory, I setup network but still does not update ever.
BuzzTV XPL 3000
Android security patch stuck on Aug 1 2016 ver
Android 6.0.1
build V001s901_20190314
Kernl Ver 3.14.29
I'm up in Canada is this blocking me ?
also is there a place i can download the files onto USB stick that is safe, so i can try this method.
thank you
2.0 352 if Emory serves me correctly
Tere are no other updates
I did factory reset of buzz tv and now it's not updating. It's version is 1.6 (162): 08/07/2018
Also "organize categories" option is also not available.
Ok so I have downloaded the file. I am new here so can you please let me know how to install the file?
install file onto usb stick ,insert into buzz and go to appinstaller in apps
  • 2 months later...
Hi,
could you also send the update file to me?  I am also in Canada and update always fails for me.
My buzz tv version is also 1.6(1.6.2) Updated 08/07/2018.
Device: BuzzTV XPL 3000
Android: 7.1.2
build: V002S901_20180906
