July 19, 20197 yr Last night my unit had an auto update and after the update the unit is stuck in boot mode. Tried several times to restart. What should I do to fix it? Please help.
July 19, 20197 yr I sent for RMA e-mail when it happened Thursday early AM EST. Got reply Buzz TV: Our team is working on a solution for XPL 3900 stuck in boot mode. Your continued Patience in this matter is appreciated. Just now the fix is being tested. It will be a download to USB thumb drive that can be used in Android recovery mode.
July 19, 20197 yr Please go here http://stbtalk.com/index.php?/topic/10-stuck-in-recovery-or-boot-fix/
July 19, 20197 yr Fix works like a charm. Extra patience (extra set of hands) will help immensely when attempting fix!
July 19, 20197 yr Inside A/V output hole on back of unit left of HDMI. Use paperclip or toothpick to feel it click. Hold down while simultaneously applying power to get in recovery screen. Took me several attempts at first then use volume up/down keys to highlight ext USB or micro SD whichever you downloaded file too. Good luck!
July 19, 20197 yr Thank you Does my USB key need to be in fat32 I got in the recovery mode one time and never after that And didn't see or read the recovery file
July 20, 20197 yr 16 hours ago, Jean-Luc said: Thank you Does my USB key need to be in fat32 I got in the recovery mode one time and never after that And didn't see or read the recovery file try formatting your USB key and transferring the file again.
