October 29, 20223 yr Hey gang, I use the x5 remote to adjust volume. I was using a sound bar controlled using it's remote but it isn't working properly - cutting in & out. Tried a new optical cable but no joy. Methinks it's on it's last legs. So, now I'm left with the volume control on the TV. Problem is, it only goes to a certain volume & no further. Oftentimes, because they are doing construction on my apartment building, I need to increase the sound to drowned out the noise & be able to listen to the TV. Often, this isn't possible because of the issue. Does anyone have an idea how I can increase the volume? Is there something in settings I need to adjust?? Thank you for any & all responses! Regards, Ray
October 29, 20223 yr Author Thx 'dishuser' - that option is checked. Figured out it affected only VOD, not Live TV or Lodi, etc. Go figure - ain't technology grand! 😂
October 29, 20223 yr 14 minutes ago, websurferdude said: Thx 'dishuser' - that option is checked. Figured out it affected only VOD, not Live TV or Lodi, etc. Go figure - ain't technology grand! 😂 try with it off and see if there's a difference
