How to Fix Buzztv 2 from Crashing
Follow these steps and it will help you fix right away.
1. Open app via Settings
2. Open Server
3. Press Menu button on your Remote
4. Select Configuration
5. Select Video Player
6. Select 2nd Player
7. Select ( Use this Player )
Then Click on Connect and you are good to go.
