XPL3900 ARQ Remote
Hey guys, I was wondering if there was a fix or update to enable better functionality with the 3900 and the ARQ-100 remote.  I find some of the buttons do nothing (Back button) while other preform the wrong function (Guide button does not bring up actual guide).  Any help would be appreciated!
dreamer
dreamer
all the buttons for ARQ100 will work on XPL3900. either your remote has the problem or you can reload the firmware to see if this helps
