Confusion Between Buzz 5 & Buzz 6?
Hello everyone,
I am a little bit confused as to which app I am supposed to use to watch IPTV. Is it Buzz 5 or Buzz 6? What are the differences between to two? What do most out there use and why?
Thanks in advance!
you can use both. buzz5 is stable however, buzz6 still being worked on to add many more features. im using both and love it. I almost have all the features on buzz6 that I want and im pretty much good to go but depends on your preferences. I would say use buzz6 and if you find issues, bugs, or need features just report to buzz team so they can fix, improve and add if possible. 🙂
