P6 will not turn off
Hi, since the last update, i am unable to turn the P6 off, from the remote.
Does anyone know how to remedy this issue.
It wouldn't turn off from the button at the front either.
It's paired with the tv, the tv remote switches everything off.
How would that work if i bought a new tv?
you can program buzz remote to your tv and can turn off with it. did you check manual?
are you sure you're in the correct section this time? 🤣
turn cec on
Turned CEC off, now it goes off from the remote.
Thanks Everyone for your help and input
