November 17, 20241 yr I did factory reset and fixed other issues but now almost no sound. I switch dvi cable to my x5 and its perfect. Volume on TV on loud and no mute buttons pushed. Set for decode, not pass through. Same either way This is on Buzztv5, 6 and tivimate Suggestions? Edited November 17, 20241 yr by Bryanm
November 17, 20241 yr 3 minutes ago, Bryanm said: I did factory reset and fixed other issues but now almost no sound. I switch dvi cable to my x5 and its perfect. Volume on TV on loud and no mute buttons pushed. Set for decode, not pass through. Same either way This is on Buzztv5, 6 and tivimate Suggestions? look in buzztv utilities
November 17, 20241 yr Author I did. All seems fine. Paired new remote to x5 and all good on x5. Powerstation almost no sound
November 17, 20241 yr Author Is this in powerstation? Tv is fine with other x5 buzztv and other use. If powerstation please let me know where. Didn't see it
November 17, 20241 yr 31 minutes ago, Bryanm said: I found max volume in remote settings. It is enabled. turn if off and check sound
